vscode 下 使用jtag下载失败
Danphy
vscode 下 使用jtag下载失败
Postby Danphy » Thu Jan 20, 2022 9:45 am
# 问题描述
使用jlink 与 链接ESP32S2-SAOLA,能进入在线调试,但点击flash的时候,弹出如下提示:
Open On-Chip Debugger v0.10.0-esp32-20210401 (2021-04-01-15:46)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
adapter speed: 9600 kHz
Info : J-Link V9 compiled Dec 13 2019 11:14:50
Info : Hardware version: 9.40
Info : VTarget = 3.311 V
Info : clock speed 9600 kHz
Info : JTAG tap: esp32s2.cpu tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : esp32s2: Target halted, PC=0x4001ABA8, debug_reason=00000004
Info : Detected ESP32-S2 chip
Info : accepting 'tcl' connection on tcp/6666
Info : dropped 'tcl' connection
launch.json 文件设置如下:
// ======================== launch.json ========================
// Use IntelliSense to learn about possible attributes.
// Hover to view descriptions of existing attributes.
// For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
"version": "0.2.0",
"configurations": [
"type": "espidf",
"request": "launch",
"name": "Debug ESP32",
"target": "build/${workspaceFolderBasename}.elf",
"cwd": "${workspaceFolder}",
"gdbpath": "${config:idf.toolsPathWin}/tools/xtensa-esp32-elf/esp-2021r1-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gdb.exe", // Path of the toolchain
"autorun": [
"target remote :3333", // Connect to OpenOCD
"mon reset halt", // Reset the chip and keep the CPUs halted
"set remote hardware-watchpoint-limit 2", // Restrict GDB to using two hardware watchpoints supported by ESP32
"flushregs", // Force GDB to get new state from the target
"thb app_main", // Insert a temporary hardware breakpoint at the main function
"c" // Resume the program. It will then stop at breakpoint inserted at app_main
// "preLaunchTask": "OpenOCD"
"type": "espidf",
"name": "flash and debug ESP32",
"autorun": [
"mon program_esp32 build/${workspaceFolderBasename}.bin 0x10000",
"idf.adapterTargetName": "esp32s2"
settings.json设置如下:
"idf.adapterTargetName": "esp32s2",
"idf.openOcdConfigs": [
"interface/jlink.cfg",
"target/esp32s2.cfg"
"idf.portWin": "COM6",
"idf.flashType":"JTAG"
感谢各位大佬回复。
Users browsing this forum: Baidu [Spider] and 16 guests
