DRAM segment data does not fit
lobis0
Postby lobis0 » Mon Jan 24, 2022 6:22 pm
I am running into a problem where I need to allocate memory for a dynamic array and it (barelly) exceeds the DRAM limit of my ESP32 board.
#include <Arduino.h>
#define IMAGE_SIZE 134400
unsigned char image[IMAGE_SIZE];
void setup()
  for (int i = 0; i < IMAGE_SIZE; i++)
    image[i] = 0;
  return;
void loop()
Is there any way to make the above code work?
My goal is to call an external function that takes a `const unsigned char *image` as an argument. If I declare this `image` array as a const array, the problem will work, but taking out the const modifier throws this exception. I could store the image data into multiple arrays since it fits in memory, perhaps there is a smart way to merge this multiple arrays into a single const array such as the one required by my external function? This would solve my issue.
Thanks!
Users browsing this forum: Google [Bot] and 16 guests
