ESP32 Cam cannot initialize after restart
MV-Fabian
Postby MV-Fabian » Mon May 09, 2022 3:30 pm
we use our ESP32-CAM in combination with a SIM800L module to transmit images to a server. Therefore, we need two operating modes: one for recording images, and one for transmitting them. We use ESP.restart() to reboot and read the requested operating mode from the SD Card.
The camera can successfully be initialized exactly once. After every following reboot, the camera cannot be initialized with this error message:
E (2243) cam_hal: cam_dma_config(280): frame buffer malloc failed
E (2244) cam_hal: cam_config(364): cam_dma_config failed
E (2244) camera: Camera config failed with error 0xffffffff
If we restart the module by removing and re-applying power, the camera initializes fine each time. Therefore, we suspect that ESP.restart() is the culprit.
This log may further illustrate the problem:
SDMMC initialization: successful!
[GSM] Serial Connection started
[GSM] Modem initialized: 1
[GSM] Current SIM status: 1
[GSM] Sim Ready!
GSM initialization: successful!
KEF Device state:
        Device mode:            Transmitting Mode
        SD initialized:          1
        GSM initialized:         1
        Cam initialized:         0
[GSM] Transmit dummy
�R��fgR
RESTART
Camera initialization: successful!
KEF Device state:
        Device mode:            Record Mode
        SD initialized:          1
        GSM initialized:         0
        Cam initialized:         1
[CAM] Taking pigtu�en..�
/1268.jpg
[CAM] File saved: /1268.jpg
[CAM] �akyng(picture/..
/4793.jpg
[CAM] File saved: /4793.jpg
[CAM] taki�g �icture...
/8357.jpg
[CAM] File saved: /8357.jpg
[CCM] Taking picture�.�
/11926.jpg
[CAM] File saved: /11926.jpg
[CAM] Taoing qicuuse...
/15487.jpg
[CAM] File saved: /15487.jpg
[CAM] Taking picture...
/19048.jpg
[CAM] File saved: /19048.jpg
/22610.jpg
[CAM] File saved: /22610.jpg
[SAMW��aokn�$pkcture...
/26171.jpg
[CAM] File saved: /26171.jpg
{CAM] Takinw pictuze...
/29733.jpg
[CAM] File saved: /29733.jpg
�R��fgR
RESTART
[GSM] Sim Ready!
KEF Device state:
        SD initialized:          1
        GSM initialized:         1
        Cam initialized:         0
�R��fgR��c�o�oo
RESTART
[CAM] Camera init failed with error 0xffffffff
Camera initialization: failed!
Error number = -1
KEF Device state:
        SD initialized:          1
        GSM initialized:         0
        Cam initialized:         0
[CAM] Not initialized
�R��fgR��c�o�oo
RESTART
[GSM] Sim Ready!
KEF Device state:
        SD initialized:          1
        GSM initialized:         1
        Cam initialized:         0
�R��fgR��c�o�oo
RESTART
Error number = -1
KEF Device state:
        SD initialized:          1
        GSM initialized:         0
        Cam initialized:         0
We initialize the camera like so:
esp_err_t init_camera()
    pinMode(led_gpio, OUTPUT);
    config.ledc_channel = LEDC_CHANNEL_0;
    config.ledc_timer = LEDC_TIMER_0;
    config.pin_d0 = Y2_GPIO_NUM;
    config.pin_d1 = Y3_GPIO_NUM;
    config.pin_d2 = Y4_GPIO_NUM;
    config.pin_d3 = Y5_GPIO_NUM;
    config.pin_d4 = Y6_GPIO_NUM;
    config.pin_d5 = Y7_GPIO_NUM;
    config.pin_d6 = Y8_GPIO_NUM;
    config.pin_d7 = Y9_GPIO_NUM;
    config.pin_xclk = XCLK_GPIO_NUM;
    config.pin_pclk = PCLK_GPIO_NUM;
    config.pin_vsync = VSYNC_GPIO_NUM;
    config.pin_href = HREF_GPIO_NUM;
    config.pin_sscb_sda = SIOD_GPIO_NUM;
    config.pin_sscb_scl = SIOC_GPIO_NUM;
    config.pin_pwdn = PWDN_GPIO_NUM;
    config.pin_reset = RESET_GPIO_NUM;
    config.xclk_freq_hz = 20000000;
    config.pixel_format = PIXFORMAT_JPEG;
    if (psramFound())
        config.frame_size = FRAMESIZE_QVGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
        config.jpeg_quality = 10;
        config.fb_count = 2;
    else
        config.frame_size = FRAMESIZE_SVGA;
        config.jpeg_quality = 12;
        config.fb_count = 1;
    cam_err = esp_camera_init(&config);
    if (cam_err == ESP_OK)
        camera_initialized = true;
    else
        Serial.printf("[CAM] Camera init failed with error 0x%x", cam_err);
    return cam_err;
We suspect that maybe some register or memory is not cleared correctly. Did anybody experience similar problems and can maybe even provide a solution? Thanks in advance!
Best Regards
icepick
Re: ESP32 Cam cannot initialize after restart
Postby icepick » Thu May 18, 2023 2:00 pm
Did you ever find a solution to this problem? I am having the same issue.
Users browsing this forum: Baidu [Spider] and 174 guests
