PROBLEM TO READ ADC GPIO 36
Raka Mahendra
Postby Raka Mahendra » Mon Jul 04, 2022 10:57 am
NEED HELP PLEASE FOR MY FINAL PROJECT ON CAMPUS.
hello guys. i will really really appreciate if u can help me.
i have a problem with gpio 36. i use this pin to measure a voltage divider.
when i just connect my ESP32 Devkit, it writes 0 ADC.
but when i combine my ESP32 with another components on PCB Board, the ADC starts from +- 3029 and changed randomly.
so what should i do to calibrate the adc when it connected with another components?
the code:
#define ADC_PIN     36
float Vmodul = 0.0;
float result = 0.0;
int value = 0;
float R1 = 68000.0; //68k
float R2 = 7500.0; //7500 ohm resistor,
void setup()
   pinMode(ADC_PIN, INPUT);
   Serial.begin(9600);
void loop()
  value = analogRead(ADC_PIN);
   Vmodul  = (value * 3.3)  / 4095.0;
   result = Vmodul   / (R2/(R1+R2));
  Serial.print("module voltage = ");
  Serial.print(Vmodul,2);
  Serial.print("volt");
  Serial.print(", real result  = ");
  Serial.print(result,2);
  Serial.println("volt");
  Serial.print(", ADC = ");
  Serial.println(value);
  Serial.println("");
  delay(1000);
the image before i connect to my pcb board:
the image after i connect to my pcb board (i dont even measure anything with my voltage divider sensor) :
ESP_Sprite
Re: PROBLEM TO READ ADC GPIO 36
Postby ESP_Sprite » Tue Jul 05, 2022 1:29 am
Pins that are not connected to anything have no determinable voltage on them. Connect them to the resistive divider and try again.
Users browsing this forum: No registered users and 157 guests
