How to enable I2S0 MCLK output via GPIO0
fanday
Postby fanday » Tue Sep 19, 2017 8:01 am
As the esp32_technical_reference_manual_en.pdf mentioned that MCLK could output via GPIO0,I try below code:
         //output clock for I2S0 to CLK_OUT1
	//pdf page 67
	//(*((int*)PIN_CTRL)) = (*((int*)PIN_CTRL))&0xFFFFFFF0;
	reg_val = REG_READ(PIN_CTRL);
	ESP_LOGI(TAG, "PIN_CTRL before:%x", reg_val);
	REG_WRITE(PIN_CTRL, 0xFFFFFFF0);
	ESP_LOGI(TAG, "PIN_CTRL after:%x", reg_val);
	//(*((int*)PIN_CTRL)) = 0xFFFFFFF0;
	PIN_FUNC_SELECT(GPIO_PIN_REG_0, 1); //GPIO0 as CLK_OUT1
unfortunately,the GPIO0 output a noise CLK.like this:
log is:
I (1372) I2S: DMA Malloc info, datalen=blocksize=240, dma_buf_count=6
I (1382) I2S: Req RATE: 44100, real rate: 44642.000, BITS: 16, CLKM: 14, BCK: 8, MCLK: 11289966.924, SCLK: 1428544.000000, diva: 64, divb: 11
D (1392) I2S: data: out 163, in: -1, ws: 25, bck: 23
I (1402) Huan: PIN_CTRL before:3ff
I (1402) Huan: PIN_CTRL after:7ff0
I (1412) wifi: n:6 0, o:1 0, ap:255 255, sta:6 0, prof:1
I (1412) I2S: Req RATE: 22050, real rate: 22321.000, BITS: 16, CLKM: 28, BCK: 8, MCLK: 5644983.462, SCLK: 714272.000000, diva: 64, divb: 22
I (1432) I2S: Req RATE: 44100, real rate: 44642.000, BITS: 16, CLKM: 14, BCK: 8, MCLK: 11289966.924, SCLK: 1428544.000000, diva: 64, divb: 11
My question is :How enable I2S0 MCLK ouput via GPIO0?
Any help will be appreciate.
ESP_Sprite
Re: How to enable I2S0 MCLK output via GPIO0
Postby ESP_Sprite » Tue Sep 19, 2017 8:54 am
Are you sure the noise is in the output on the GPIO and not your measuring system? You can easily get stuff like this if your probes bandwith is too low, you use pigtails off the probe pin, or your ground isn't in the right position.
fanday
Postby fanday » Wed Sep 20, 2017 2:21 am
ESP_Sprite wrote:Are you sure the noise is in the output on the GPIO and not your measuring system? You can easily get stuff like this if your probes bandwith is too low, you use pigtails off the probe pin, or your ground isn't in the right position.
Hi ESP_Sprite,
I have measure the WS and BCLK at the same time, and the signal is quite good.So there is no problem with measuring system. I guess I have not configure the MCLK output properly.Please check my code below:
   //pdf page 67
any sample code?Thanks.
fanday
Postby fanday » Wed Sep 20, 2017 2:27 am
I have measured the WS and BCLK and signal is good,except the MCLK.Please help tcheck my code:
   //pdf page 67
any sample code will be great.Thanks.
ESP_Sprite
Postby ESP_Sprite » Wed Sep 20, 2017 3:27 am
Sure, but WS and BCLK are an order of magnitude slower than the MCLK signal. Can you show me these signals on the same scope setup? I'm still not sure your noise comes fromt he ESP32 and not your setup; it looks distinctly analog and rlc-based to me.
Janet2018
Postby Janet2018 » Mon Jul 16, 2018 6:42 am
   //pdf page 67
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_GPIO0_CLK_OUT1);
REG_WRITE(PIN_CTRL, 0);
npashine
Postby npashine » Tue Oct 02, 2018 6:12 pm
Im trying to use i2s with sgtl5000 and stuck with MCLK generation.
Also my board don't have GPIO0 pin as it used as boot pin as button.
Kindly tell how can I generate 385*Fs(385*44100=16978500) or 256*Fs or 512*Fs via CLK_OUT3.
using below 2 functions but don't know how to divide the clock also please tell the clk_out3 source.
PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0TXD_U, FUNC_U0TXD_CLK_OUT3);
REG_WRITE(PIN_CTRL,0xFFFFF0F0);
dekelm8
Postby dekelm8 » Mon Dec 10, 2018 11:20 pm
Hey
Have you succeed to set the mclk to 512fs?
ESP_houwenxiang
Postby ESP_houwenxiang » Wed Dec 12, 2018 3:15 am
Just as Janet2018 suggested, I2S0 MCLK can output from IO0 , but note IO0 should not be connected to a capacitor.
wookooho
Users browsing this forum: No registered users and 248 guests
