mbedcrypto lib unable to resolve external function
gc-wesd
Postby gc-wesd » Fri Dec 02, 2022 6:37 pm
ESP-IDF v4.1.3
CPU: ESP32 Rev 3
I'm porting an application that builds in Linux using makefiles to Windows using cmake. The build almost succeeds except for the inability to coax the ESP-IDF mbedcrypto library to find a function located in our cryptoauthlib component.
The application CMakeLists.txt file includes this switch: add_compile_definitions(MBEDTLS_ECDSA_SIGN_ALT)
telling mbedtls to use the alternative signing function which is provided by cryptoauthlib. Using objdump I verify the function 'mbedtls_ecdsa_sign' is present in cryptoauthlib.
The build ends with this failure:
cmd.exe /C "cd . && C:\Users\wesd\.espressif\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-g++.exe  -mlongcalls -Wno-frame-address   @CMakeFiles\ww-halo.elf.rsp  -o ww-halo.elf  && cd ."
c:/users/wesd/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a(ecdsa.c.obj):(.literal.ecdsa_sign_det_restartable+0x8): undefined reference to `mbedtls_ecdsa_sign'
c:/users/wesd/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a(ecdsa.c.obj): in function `ecdsa_sign_det_restartable':
C:/Users/wesd/dev/ww_halo/halo_fw/esp-idf/components/mbedtls/mbedtls/library/ecdsa.c:489: undefined reference to `mbedtls_ecdsa_sign'
I'm fairly new working with cmake - is there something I need to do to induce the ESP mbedcrypto library to seach cryptoauthlib? I'm trying to avoid changing any CMakeLists.txt files in the IDF, tree but maybe it's necessary?
Users browsing this forum: MicroController and 208 guests
