Netconn_delete return ERR_VAL
JKozlo
Postby JKozlo » Sun Sep 24, 2017 7:38 pm
in my program, I check error value, which netconn_close and netconn_delete return. Netconn_close return ERR_OK, but after it netconn_delete return ERR_VAL(-6). It is normal situation ?
Here is my code:
#include "esp_wifi.h"
#include "esp_system.h"
#include "esp_event.h"
#include "esp_event_loop.h"
#include "nvs_flash.h"
#include "driver/gpio.h"
#include "freertos/portmacro.h"
#include "esp_log.h"
#include "tcpip_adapter.h"
#include "lwip/priv/api_msg.h"
#include "lwip/sockets.h"
#include "lwip/tcp.h"
#include "lwip/sys.h"
#include "lwip/netdb.h"
#include "lwip/api.h"
#include "lwip/err.h"
#include "lwip/netbuf.h"
#include "lwip/netifapi.h"
#include "lwip/pppapi.h"
#include "string.h"
#include "cJSON.h"
#define MEMP_NUM_NETCONN 20
SemaphoreHandle_t taskSemaphore = NULL;
char* json_unformatted;
static EventGroupHandle_t wifi_event_group;
const int CONNECTED_BIT = BIT0;
//static char* TAG = "app_main";
bool sta_is_configured = false;
char* ssid;
char* pwd;
struct netconn conn_array[5];
struct channel
  char name[80];
  char data_str[80];
  int data_int;
struct channel channel_list[10];
#define delay(ms) (vTaskDelay(ms/portTICK_RATE_MS))
const static char http_html_hdr[] =
    "HTTP/1.1 200 OK\r\nContent-type: text/html\r\n\r\n";
const static char http_index_hml[] = "<!DOCTYPE html>"
      "<html>\n"
      "<head>\n"
      "  <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n"
      "  <style type=\"text/css\">\n"
      "    html, body, iframe { margin: 0; padding: 0; height: 100%; }\n"
      "    iframe { display: block; width: 100%; border: none; }\n"
      "  </style>\n"
      "<title>HELLO ESP32</title>\n"
      "</head>\n"
      "<body>\n"
      "<h1>Hello World, from ESP32!</h1>\n"
      "</body>\n"
      "</html>\n";
char http_index_hml_sta_config[] = "<!DOCTYPE html>"
      "<html>\n"
      "<head>\n"
      "</head>\n"
      "<body>\n"
      "<form name=\"myForm\" onsubmit=\"sendForm(); return false;\">\n"
      "SSID:<br><input type=\"text\" name=\"ssid\" value=\"\"><br>\n"
      "PASS:<br><input type=\"text\" name=\"pass\" value=\"\"><br>\n"
      "<input type=\"submit\" value=\"Zapisz\">\n"
      "</form><br>\n"
      "<script>\n"
      "function sendForm() {\n"
      "var x = document.forms[\"myForm\"][\"ssid\"].value;\n"
      "var y = document.forms[\"myForm\"][\"pass\"].value;\n"
      "var xhttp = new XMLHttpRequest();\n"
      "xhttp.onreadystatechange = function() {\n"
      "if (this.readyState == 4 && this.status == 200) {\n"
      "location.reload(true);\n"
      "}\n"
      "};\n"
      "var url = \"?ssid=\"+x+\"&pass=\"+y;\n"
      "xhttp.open(\"GET\", url, true);\n"
      "xhttp.send();\n"
      "document.forms[\"myForm\"].reset()};\n"
      "</script>\n"
      "</body>\n"
      "</html>\n";
char http_index_hml_tmp[] = "<!DOCTYPE html>"
      "<html style=\"height: 100%;\">\n"
      "<body style=\"color:white; background:linear-gradient(141deg, #0fb8ad 0%, #1fc8db 51%, #2cb5e8 75%);\">\n"
      "</head>\n"
      "<body>\n"
      "Kanal:<br><input type=\"text\" name=\"channel_add\" value=\"\"><br>\n"
      "<input type=\"submit\" value=\"Dodaj kanal\">\n"
      "</form><br>\n"
      "<div style=\"float: left; width: 15%;\">\n"
      "Kanal:\n"
      "<ul id = \"channel\"> </ul>\n"
      "</div>\n"
      "Pomiary:\n"
      "<ul id = \"data\" style=\"list-style: none;\"> </ul>\n"
      "</div>\n"
      "<script>\n"
      "var x = document.forms[\"myForm\"][\"channel_add\"].value;\n"
      "var url = \"?channel_add=\"+x;\n"
      "xhttp.send();\n"
      "setInterval(function(){\n"
      "obj = JSON.parse(this.responseText);\n"
      "var outleft = \"\";\n"
      "var outright = \"\";\n"
      "var i;\n"
      "for(i = 0; i < obj.length; i++) {\n"
        "outleft += \"<li>\"+obj[i].Name +\"</li>\";\n"
        "outright += \"<li>\"+obj[i].Data +\"&nbsp\"+\"</li>\";\n"
      "}\n"
      "document.getElementById(\"channel\").innerHTML = outleft;\n"
      "document.getElementById(\"data\").innerHTML = outright;\n }\n };\n"
      "xhttp.open(\"GET\", \"&\", true);\n"
      "xhttp.send();\n },10000);\n"
      "</script>\n </body>\n </html>\n";
int num = 0;
static void generate_json() {
  cJSON *root, *d;
  root = cJSON_CreateArray();
  for(int i = 0;i<10;i++)
      if(channel_list[i].name[0] != 0)
      cJSON_AddItemToArray(root, d = cJSON_CreateObject());
      cJSON_AddStringToObject(d, "Name", channel_list[i].name);
      cJSON_AddStringToObject(d, "Data", channel_list[i].data_str);
  json_unformatted = cJSON_PrintUnformatted(root);
  printf("[len = %d]  ", strlen(json_unformatted));
  printf("%s\n", json_unformatted);
static esp_err_t event_handler(void *ctx, system_event_t *event)
    switch(event->event_id) {
    case SYSTEM_EVENT_STA_START:
        esp_wifi_connect();
    case SYSTEM_EVENT_STA_GOT_IP:
        xEventGroupSetBits(wifi_event_group, CONNECTED_BIT);
        printf("got ip\n");
        printf("ip: " IPSTR "\n", IP2STR(&event->event_info.got_ip.ip_info.ip));
        printf("netmask: " IPSTR "\n", IP2STR(&event->event_info.got_ip.ip_info.netmask));
        printf("gw: " IPSTR "\n", IP2STR(&event->event_info.got_ip.ip_info.gw));
        printf("\n");
        fflush(stdout);
    case SYSTEM_EVENT_STA_DISCONNECTED:
        /* This is a workaround as ESP32 WiFi libs don't currently
           auto-reassociate. */
        esp_wifi_connect();
        xEventGroupClearBits(wifi_event_group, CONNECTED_BIT);
    default:
    return ESP_OK;
static void initialise_wifi(void)
    tcpip_adapter_init();
    wifi_event_group = xEventGroupCreate();
    ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
    ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
    ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_AP) );
    wifi_config_t  ap_config =
    .ap =
      .ssid = "czesc",
      .password = "12345678",
      .authmode = WIFI_AUTH_WPA_WPA2_PSK,
      .ssid_len = 0,
      .max_connection = 16,
    ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_AP, &ap_config) );
static void
http_server_netconn_serve(struct netconn *conn)
  printf("%d\n", esp_get_free_heap_size());
  struct netbuf *inbuf;
  char  *buf;
  u16_t buflen;
  char* buf_temp = malloc(sizeof(char)*80);
  char* ChannelToAddMeasure = malloc(sizeof(char)*80);
  /* Read the data from the port, blocking if nothing yet there.
   We assume the request (the part we care about) is in one netbuf */
   netconn_write(conn, http_html_hdr, sizeof(http_html_hdr)-1, NETCONN_NOCOPY);
  if (netconn_recv(conn, &inbuf) == ERR_OK) {
   err_t err2 = netbuf_data(inbuf,(void**)&buf,&buflen);
   printf("EEEEEEE%d\n", err2);
    /* Is this an HTTP GET command? (only check the first 5 chars, since
    there are other formats for GET, and we're keeping it very simple )*/
    printf("buffer = %s \n", buf);
    printf("buflen = %d\n", buflen);
    if (buflen>=5 && buf[0]=='G' && buf[1]=='E' && buf[2]=='T' && buf[3]==' ' && buf[4]=='/' && buf[5]=='&' )
        generate_json();
        printf("po funkcji\n");
        err_t err_write;
        err_write = netconn_write(conn, json_unformatted, strlen(json_unformatted), NETCONN_NOCOPY);
        printf("%d\n", err_write);
        free(json_unformatted);
        printf("po write\n");
        printf("po free\n");
    else if (buflen>=5 && buf[0]=='G' && buf[1]=='E' && buf[2]=='T' && buf[3]==' ' && buf[4]=='/' && buf[5]=='!' )
        int HTTP_pos=6;
        int measure_pos=0;
        int liczba;
        int ChannelToAddMeasurePos=0;
        memset(buf_temp,0,sizeof(char)*80);
        memset(ChannelToAddMeasure,0,sizeof(char)*80);
        printf("tutaj\n");
        while(buf[HTTP_pos]!='H')
          HTTP_pos+=1;
        printf("tutaj1\n");
        strncpy(buf_temp,strstr(buf,"channel_add=")+sizeof(char)*12,sizeof(char)*(HTTP_pos-19));
        printf("%s\n", buf_temp);
        printf("tutaj2\n");
        while(buf_temp[measure_pos]!=':')
          measure_pos+=1;
        strncpy(ChannelToAddMeasure,buf_temp,sizeof(char)*measure_pos);
        printf("%s\n",ChannelToAddMeasure);
        while(strcmp(channel_list[ChannelToAddMeasurePos].name,ChannelToAddMeasure)!=0)
          ChannelToAddMeasurePos+=1;
          if(ChannelToAddMeasurePos>10)
        if(ChannelToAddMeasurePos<10)
        strcpy(ChannelToAddMeasure,buf_temp+measure_pos+1);
        printf("%s\n", ChannelToAddMeasure);
        liczba = strtol(ChannelToAddMeasure,NULL,10);
        printf("liczba= %d\n", liczba-1);
         strcpy(channel_list[ChannelToAddMeasurePos].data_str,ChannelToAddMeasure);
  else if (buflen>=5 && buf[0]=='G' && buf[1]=='E' && buf[2]=='T' && buf[3]==' ' && buf[4]=='/' && buf[5]=='?' && sta_is_configured) {
        int HTTP_pos=6;
        int FemptyPos=0;
        printf("tutaj\n");
        while(buf[HTTP_pos] != 'H')
          HTTP_pos+=1;
        while(channel_list[FemptyPos].name[0] != 0 && strcmp(channel_list[FemptyPos].name,buf_temp) != 0)
          FemptyPos+=1;
        printf("slowo = %s\n", buf_temp);
        printf("%d\n", FemptyPos);
        strcpy(channel_list[FemptyPos].name ,buf_temp);
        for(int k = 0;k<=FemptyPos;k++)
          printf("%s\n",channel_list[k].name );
  else if (buflen>=5 && buf[0]=='G' && buf[1]=='E' && buf[2]=='T' && buf[3]==' ' && buf[4]=='/' && buf[5]=='?' && !sta_is_configured) {
        int and_pos=6;
        printf("tutaj");
        ssid = malloc(sizeof(char)*80);
        pwd = malloc(sizeof(char)*80);
        memset(ssid,0,sizeof(char)*80);
        memset(pwd,0,sizeof(char)*80);
        while(buf[and_pos] != '&')
            and_pos+=1;
          printf("tutaj1");
        strncpy(ssid,strstr(buf,"ssid=")+sizeof(char)*5,sizeof(char)*(and_pos-11));
        int HTTP_pos = 0;
            HTTP_pos+=1;
          printf("tutaj2");
        strncpy(pwd,strstr(buf,"pass=")+sizeof(char)*5,sizeof(char)*(HTTP_pos-(and_pos+7)));
        printf("ssid= %s\n", ssid);
        printf("haslo= %s\n",pwd );
        free(ssid);
        free(pwd);
        sta_is_configured = true;
        //initialise_wifi();
    else
      if(!sta_is_configured) {netconn_write(conn, http_index_hml_sta_config, sizeof(http_index_hml_sta_config)-1, NETCONN_NOCOPY);}
      else {netconn_write(conn, http_index_hml_tmp, sizeof(http_index_hml_tmp)-1, NETCONN_NOCOPY);}
  printf("Przed close\n");
  err_t err1;
  // Close the connection (server closes in HTTP)
  err1 = netconn_close(conn);
  printf("Po close, err = %d\n",err1);
  err1 = netconn_delete(conn);
  printf("Po delete, err = %d\n",err1);
  /* Delete the buffer (netconn_recv gives us ownership,
   so we have to make sure to deallocate the buffer) */
  //free(inbuf);
  //netbuf_free(inbuf);
  netbuf_delete(inbuf);
  free(buf_temp);
  free(ChannelToAddMeasure);
  if (taskSemaphore != NULL && xSemaphoreTake(taskSemaphore, 100 / portTICK_PERIOD_MS) == pdTRUE) // oczekiwanie 1s
          printf("NUM====%d\n", num);
        num=num-1;
        xSemaphoreGive(taskSemaphore);
  vTaskDelete(NULL);
static void http_server(void *pvParameters)
  struct netconn *conn;
  taskSemaphore = xSemaphoreCreateMutex();
  err_t err;
  conn = netconn_new(NETCONN_TCP);
  netconn_bind(conn, NULL, 80);
  netconn_listen(conn);
  do {
      struct netconn *newconn;
      err = netconn_accept(conn,&newconn);
     if (err == ERR_OK) {
          printf("haslko\n");
        newconn->recv_timeout=10;
        conn_array[num] = *newconn;
        xTaskCreate(&http_server_netconn_serve,"http_server_netconn_serve",4096,&conn_array[num],5,NULL);
        num=num+1;
     //free(newconn);
     fflush(stdout);
     printf("newconn %d\n",sizeof(newconn));
     printf("struct %d\n",sizeof(struct netconn*) );
   } while(err == ERR_OK);
    vTaskDelete(NULL);
int app_main(void)
    nvs_flash_init();
    esp_wifi_restore();
    initialise_wifi();
    xTaskCreate(&http_server, "http_server", 4096, NULL, 5, NULL);
    return 0;
Maybe someone has idea what is wrong ?
Thanks in advance
Users browsing this forum: Google [Bot] and 243 guests
