- I (0) cpu_start: App cpu up.
- I (441) cpu_start: Pro cpu start user code
- I (441) cpu_start: cpu freq: 160000000 Hz
- I (441) cpu_start: Application information:
- I (446) cpu_start: Project name: app-template
- I (451) cpu_start: App version: v5.0.1-dirty
- I (456) cpu_start: Compile time: Mar 27 2023 12:04:10
- I (462) cpu_start: ELF file SHA256: 840ea042f77f29b6...
- I (468) cpu_start: ESP-IDF: v5.0.1-dirty
- I (474) cpu_start: Min chip rev: v0.0
- I (479) cpu_start: Max chip rev: v3.99
- I (483) cpu_start: Chip rev: v1.0
- I (488) heap_init: Initializing. RAM available for dynamic allocation:
- I (495) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
- I (501) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
- I (507) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
- I (514) heap_init: At 3FFC7D58 len 000182A8 (96 KiB): DRAM
- I (520) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
- I (526) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
- I (533) heap_init: At 400980EC len 00007F14 (31 KiB): IRAM
- I (540) spi_flash: detected chip: generic
- I (543) spi_flash: flash io: dio
- I (549) cpu_start: Starting scheduler on PRO CPU.
- I (0) cpu_start: Starting scheduler on APP CPU.
- E (558) task_wdt: esp_task_wdt_reset(783): task not found
- ets Jun 8 2016 00:22:57
- rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
- configsip: 0, SPIWP:0xee
- clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
- mode:DIO, clock div:2
- load:0x3fff0030,len:7132
- ho 0 tail 12 room 4
- load:0x40078000,len:16204
- load:0x40080400,len:3644
- 0x40080400: _init at ??:?
- entry 0x40080698
- I (57) boot: ESP-IDF v5.0.1-dirty 2nd stage bootloader
- I (57) boot: compile time 12:04:08
- I (58) boot: chip revision: v1.0
- I (62) boot.esp32: SPI Speed : 40MHz
- I (66) boot.esp32: SPI Mode : DIO
- I (71) boot.esp32: SPI Flash Size : 4MB
- W (75) boot.esp32: PRO CPU has been reset by WDT.
- W (81) boot.esp32: WDT reset info: PRO CPU PC=0x4008cc24
- 0x4008cc24: _xt_panic at E:/esp-idf-v5.0.1/components/esp_system/port/arch/xtensa/panic_handler_asm.S:28
- W (87) boot.esp32: WDT reset info: APP CPU PC=0x400911c2
- 0x400911c2: panic_handler at E:/esp-idf-v5.0.1/components/esp_system/port/panic_handler.c:140 (discriminator 1)
- I (93) boot: Enabling RNG early entropy source...
- I (98) boot: Partition Table:
- I (102) boot: ## Label Usage Type ST Offset Length
- I (109) boot: 0 nvs WiFi data 01 02 00012000 00004000
- I (117) boot: 1 otadata OTA data 01 00 00016000 00002000
- I (124) boot: 2 phy_init RF data 01 01 00018000 00001000
- I (132) boot: 3 factory factory app 00 00 00020000 00100000
- I (139) boot: 4 ota_0 OTA app 00 10 00120000 00100000
- I (147) boot: 5 ota_1 OTA app 00 11 00220000 00100000
- I (155) boot: End of partition table
- I (159) boot: Defaulting to factory image
- I (163) esp_image: segment 0: paddr=00020020 vaddr=3f400020 size=22188h (139656) map
- I (209) esp_image: segment 1: paddr=000421b0 vaddr=3ffbdb60 size=04b08h ( 19208) load
- I (215) esp_image: segment 2: paddr=00046cc0 vaddr=40080000 size=09358h ( 37720) load
- I (227) esp_image: segment 3: paddr=00050020 vaddr=400d0020 size=8d1a4h (577956) map
- I (382) esp_image: segment 4: paddr=000dd1cc vaddr=40089358 size=0ed94h ( 60820) load
- I (413) boot: Loaded app from partition at offset 0x20000
- I (413) boot: Disabling RNG early entropy source...
- I (424) cpu_start: Pro cpu up.
- I (424) cpu_start: Starting app cpu, entry point is 0x400813c8
- 0x400813c8: call_start_cpu1 at E:/esp-idf-v5.0.1/components/esp_system/port/cpu_start.c:142
ESP32 goes rebooting
Re: ESP32 goes rebooting
Again
this coming.
- Error: All app partitions are too small for binary app-template.bin size 0x14c1f0:
- - Part 'factory' 0/0 @ 0x20000 size 0x100000 (overflow 0x4c1f0)
- - Part 'ota_0' 0/16 @ 0x120000 size 0x100000 (overflow 0x4c1f0)
- - Part 'ota_1' 0/17 @ 0x220000 size 0x100000 (overflow 0x4c1f0)
- ninja: build stopped: subcommand failed.
Users browsing this forum: No registered users and 158 guests
