HI! I am new in this forum so forgive me if this topic should be placed in another space (Documentation/Sample Code/Hardware/Etc...)
I am also new with the Esp32. At this moment I have done a couple of projects with the esp32 but in my opinion very easy, without getting deep in the hardware nor the firmware.
I would like to implement a neuronal network in the esp32, and following the documentation I came across with this example: https://github.com/espressif/esp-dl/tre ... ol_example. I have followed the tutorial and flash it in a esp32 devkit (this https://www.amazon.es/dp/B071P98VTG/ref ... 87QA3&th=1).
However I get the following error:
"E (312) psram: PSRAM ID read error: 0xffffffff
E (312) cpu_start: Failed to init external RAM!"
What could be the problem? How can I solve it?
Thank you very much in advance!
Esp-dl problem with psram
Re: Esp-dl problem with psram
Is your board/module actually equipped with PSRAM? It doesn't come as standard with all modules/boards.
Thank you for your answer! How can I know if the ESP32 is eqquiped with PSRAM? Do you know if it is necessary to run esp-dl library?ESP_Sprite wrote: ↑Tue Mar 28, 2023 11:52 pmIs your board/module actually equipped with PSRAM? It doesn't come as standard with all modules/boards.
Hi!
Thank you for your answer! Hoy can I know if it is equipped with PSRAM?
Acording to the documentation (https://github.com/espressif/esp-dl) "
Thank you in advanced!
" I supposed that it would work with a standard dev-kit module... Should I include any other peripheral?As ESP-DL does not need any peripherals [...]
It's because ESP-DL by itself doesn't require psram. It simply happens to be used with models that use a fair amount of memory, and in that case you want psram to stash your data in. If your models and other memory requirements are small enough, esp-dl will happily work from internal memory alone as well.
You can usually either look up the information of the devboard, or lacking that the datasheet of the module on the devboard. That'll tell you details wrt the amount of psram, if any, it has.
Users browsing this forum: No registered users and 175 guests
