Using Windows. I followed the default toolchain setup.
During make flash for "hello_world" project I get a python error:
kannhild@kanm5428 MINGW32 ~/esp/hello_world
$ make flash
ImportError: No module named site
I tried to fix this by setting the PYTHONPATH, but ran into further issues with not finding _collections. I don't know where this file is.
$ export PYTHONPATH="/mingw32/lib/python2.7/:/mingw32/lib/python2.7/site-packages"
$ make flash
File "C:/msys32/home/kannhild/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 21, in <module>
import argparse
File "C:/msys32/mingw32/lib/python2.7/argparse.py", line 85, in <module>
import collections as _collections
I am considering abandoning the Windows Environment and trying ubuntu but I expected this to work as default.
Any help?
Python issues - ImportError: No module named site
Re: Python issues - ImportError: No module named site
It looks like the MSYS2 Python installation is somehow very broken.
Can you please run the following commands in the MINGW32 terminal and post the results:
which python
python -V
echo $PATH
$ which python
/mingw32/bin/python
$ python -V
Python 2.7.14
$ echo $PATH
/mingw32/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/opt/xtensa-esp32-elf/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl;/mingw32/lib/python2.7/
$ which python
/mingw32/bin/python
$ python -V
Python 2.7.14
$ echo $PATH
Thanks nathan. This all looks correct to me, I can't really explain how it's failing to import built-in Python modules.
Did you download and unzip the all-in-one environment and toolchain from here?
http://esp-idf.readthedocs.io/en/latest ... hain-setup
Is it possible the installation somehow may have been corrupted, or ran out of space at some point?
Yes I downloaded and uncompressed from that link. I tried it multiple times and no luck.
I am sure I did not corrupt as I ran only the "Getting Started" procedure.
Anyway, I have switched to ubuntu for development and the environment is working as expected.
Users browsing this forum: netfox and 151 guests
