Problems with ESP NOW connection
diegocefetmg
Postby diegocefetmg » Fri Apr 20, 2018 11:08 am
Hello;
I'm new on ESP32 board and there is a situation that I could not handle. I'm trying to make a simple connection with WIFI and ESP NOW protocol. I started with a esp exemple and in beginning works fine, but only after the compilation. When I turn they off, a master can not find a slave any more and shows this message:
Found -2 devices
Slave Not Found, trying again.
E (12096) wifi: esp_wifi_scan_start 967 wifi not start
I'm using ARDUINO IDE and the code is the demo ESP32->ESP NOW->Basics->Master and ESP32->ESP NOW->Basics->Slave
Help!!!
debrucer
Re: Problems with ESP NOW connection
Postby debrucer » Sun May 06, 2018 5:08 am
E (392115) wifi: esp_wifi_scan_start 967 wifi not start
Same problem, Same example code being used.
The error occurs on the following line:
if ( 6 == sscanf(BSSIDstr.c_str(), "%x:%x:%x:%x:%x:%x%c", &mac[0], &mac[1], &mac[2], &mac[3], &mac[4], &mac[5] ) ) {
That "%c" is the offender. Delete it and recompile and you will get to the next failure. I believe that %c is a character variable, i.e., it's not a string, and it's not a number. It probably holds the work "slave" or perhaps "Slave", so without that value. well, you will see when you get to the next error :)
Hope this helps!
Users browsing this forum: Bing [Bot], Bytespider, ChatGPT-User, Semrush [Bot] and 1 guest
