deadlock calling pppapi_free
Ivan_G
Postby Ivan_G » Fri May 11, 2018 4:40 pm
I'm facing the following issue, (code attached below) once pppapi_free been called the current task goes to a deadlock, checking docs, seems that pppapi_free should be called inside tcpip thread but I didn't find any way to do that.
I also checked on espidf ppp example, but there isn't a ppp_pcb release.
Anyone has a full example of ppp re-creation?
All suggestions are welcome, thanks in advance
static ppp_pcb *ppp = NULL;
static bool gsm_ppp_connect()
	ESP_LOGW(TAG, "gsm_ppp_connect 1");
	if(ppp != NULL)
		pppapi_free(ppp);
		ppp = NULL;
	ESP_LOGW(TAG, "gsm_ppp_connect 2");
	ppp = pppapi_pppos_create(&ppp_netif, ppp_output_callback, ppp_status_cb, NULL);
	if (ppp == NULL)
		ESP_LOGE(TAG, "Error initializing PPPoS");
		return false;
	ESP_LOGW(TAG, "gsm_ppp_connect 3");
	pppapi_set_default(ppp);
	ESP_LOGW(TAG, "gsm_ppp_connect 4");
	pppapi_set_auth(ppp, PPPAUTHTYPE_PAP, config->gsm_user, config->gsm_pass);
	ESP_LOGW(TAG, "gsm_ppp_connect 5");
	pppapi_connect(ppp, 0);
	ESP_LOGW(TAG, "gsm_ppp_connect 6");
	return true;
torarqui
Re: deadlock calling pppapi_free
Postby torarqui » Wed Oct 23, 2019 4:53 pm
Did you manage to resolve this issue? I have the same problem
