Benchmark: DAC versus Sigma-Delta
JoaoLopesF
Postby JoaoLopesF » Sun Jun 10, 2018 4:45 pm
I did a benchmark of DAC x Sigma-Delta:
 * main.c
 *  Created on: 9 de jun de 2018
 *      Author: Joao Lopes
#include <stdio.h>
#include <stddef.h>
#include "esp_types.h"
#include "esp_system.h"
#include "esp_log.h"
#include "sdkconfig.h"
#include "esp_timer.h"
#include <driver/dac.h>
#include "driver/gpio.h"
#include "driver/sigmadelta.h"
static const char *tag = "Benchmark";
void app_main()
	ESP_LOGI (tag, "Main - Begin");
	// Initialize DAC
	dac_output_enable(DAC_CHANNEL_1);
	// Initialize Sigma Delta
    sigmadelta_config_t sigmadelta_cfg = {
        .channel = SIGMADELTA_CHANNEL_0,
        .sigmadelta_prescale = 80,
        .sigmadelta_duty = 0,
        .sigmadelta_gpio = 4,
    sigmadelta_config(&sigmadelta_cfg);
    // Variables
	uint16_t times = 100;
	uint64_t timeBegin;
	float avg;
	// Dac
	timeBegin = esp_timer_get_time();
	for (uint16_t i = 0; i<times; i++) {
		dac_output_voltage(DAC_CHANNEL_1, 100);
	uint32_t totalTimeDac = (esp_timer_get_time() - timeBegin);
	avg = ((float) totalTimeDac / (float) times);
	ESP_LOGI(tag, "*** DAC Time total %u avg %f", totalTimeDac, avg);
	// SigmaDelta
        sigmadelta_set_duty(SIGMADELTA_CHANNEL_0, 100);
	uint32_t totalTimeSigmaDelta = (esp_timer_get_time() - timeBegin);
	avg = ((float) totalTimeSigmaDelta / (float) times);
	ESP_LOGI(tag, "*** SigmaDelta Time total %u avg %f", totalTimeSigmaDelta, avg);
	ESP_LOGI(tag, "*** Factor Dac/SigmaDelta %.2f %%", (totalTimeDac / totalTimeSigmaDelta) * 100.0f);
	ESP_LOGI (tag, "Main - End");
Output on Monitor (@ 160MHz):
I (169)P(01) Benchmark: Main - Begin
I (169)P(00) Benchmark: *** DAC Time total 454 avg 4.540000
I (169)P(00) Benchmark: *** SigmaDelta Time total 32 avg 0.320000
I (169)P(00) Benchmark: *** Factor Dac/SigmaDelta 1400.00 %
I (179)P(10) Benchmark: Main - End
Sigma-Delta have a very good time (0.32 us) :-)
Why DAC is 1400% more slow than Sigma-Delta ?
ESP_Sprite
Re: Benchmark: DAC versus Sigma-Delta
Postby ESP_Sprite » Mon Jun 11, 2018 2:09 am
Because at least that DAC output routine is not optimized for speed. For most people who want to get speed out of the DAC, they're better off connecting it to the I2S peripheral and feeding it that way. You can get multiple MHzs of speed that way without any CPU interference.
JoaoLopesF
Postby JoaoLopesF » Mon Jun 11, 2018 10:33 pm
Hi, ESP_Sprite
Thanks for you response.
I modified the program to do benchmark in core 1 too:
 * main.c
#include <stdio.h>
#include <stddef.h>
#include "freertos/task.h"
// Variables
const uint16_t timesBenchmark = 1u;
const uint16_t timesOutput = 1000u;
uint32_t totalTimeDac[2] = {0, 0};
uint32_t totalTimeSigmaDelta[2] = {0, 0};
// Benchmark
void benchmark() {
    // Variables
	uint64_t timeBegin = 0u;
	float avg = 0.0f;
	// Benchmark
    ESP_LOGI(tag, "***  Benchmark DAC/SigmaDelta - on core %d", xPortGetCoreID());
    for (uint8_t i=1; i<=timesBenchmark; i++) {
    	ESP_LOGI(tag, "*** Benchmark: %d", i);
    	// Dac
    	for (uint16_t i = 0; i<timesOutput; i++) {
    		dac_output_voltage(DAC_CHANNEL_1, 100u);
    	uint32_t timeDac = (esp_timer_get_time() - timeBegin);
    	totalTimeDac[xPortGetCoreID()] += timeDac;
    	avg = ((float) timeDac / (float) timesOutput);
    	ESP_LOGI(tag, "*** DAC        Time total %u avg %.3f", timeDac, avg);
    	// SigmaDelta
            sigmadelta_set_duty(SIGMADELTA_CHANNEL_0, 100u);
    	uint32_t timeSigmaDelta = (esp_timer_get_time() - timeBegin);
    	totalTimeSigmaDelta[xPortGetCoreID()] += timeSigmaDelta;
    	avg = ((float) timeSigmaDelta / (float) timesOutput);
    	ESP_LOGI(tag, "*** SigmaDelta Time total %u avg %.3f", timeSigmaDelta, avg);
    	ESP_LOGI(tag, "*** Factor Dac/SigmaDelta %.2f %%", (timeDac / timeSigmaDelta) * 100.0f);
// Averages for CPU
void averagesCPU() {
	ESP_LOGW(tag, "*** Average for Core ***");
	float avg = 0.0f;
	for (uint8_t c=0; c<=1; c++) {
		ESP_LOGW(tag, "*** Core %d", c);
		avg = ((float) totalTimeDac[c] / (float) timesOutput / (float) timesBenchmark);
		ESP_LOGI(tag, "*** DAC        avg %.3f", avg);
		avg = ((float) totalTimeSigmaDelta[c] / (float) timesOutput / (float) timesBenchmark);
		ESP_LOGI(tag, "*** SigmaDelta avg %.3f", avg);
		ESP_LOGI(tag, "*** Factor Dac/SigmaDelta %.2f %%", (totalTimeDac[c] / totalTimeSigmaDelta[c]) * 100.0f);
	ESP_LOGW(tag, "********");
static void benchmarkCPU1_task(void *arg) {
	// Task on CPU 1 to rum the benchmark
	benchmark();
	// Averages for CPU
	averagesCPU();
	// Delete this task
	vTaskDelete(NULL);
	// Task das atividades dos leds
void app_main()
	// Initialize DAC
    // Benchmark on CPU 0
    benchmark();
    // Benchmark on CPU 1
	xTaskCreatePinnedToCore(&benchmarkCPU1_task, "bench_task", 5120, NULL, 15, NULL, APP_CPU_NUM);
	// End
Monitor output (Esp32 @160MHz):
I (169)P(00) Benchmark: ***  Benchmark DAC/SigmaDelta - on core 0
I (169)P(00) Benchmark: *** Benchmark: 1
I (179)P(10) Benchmark: *** DAC        Time total 4334 avg 4.334
I (179)P(00) Benchmark: *** SigmaDelta Time total 280 avg 0.280
I (179)P(00) Benchmark: *** Factor Dac/SigmaDelta 1500.00 %
I (179)P(00) Benchmark: Main - End
I (179)P(00) Benchmark: ***  Benchmark DAC/SigmaDelta - on core 1
I (189)P(10) Benchmark: *** Benchmark: 1
I (189)P(00) Benchmark: *** DAC        Time total 4313 avg 4.313
I (189)P(00) Benchmark: *** SigmaDelta Time total 296 avg 0.296
I (189)P(00) Benchmark: *** Factor Dac/SigmaDelta 1400.00 %
W (199)P(10) Benchmark: *** Average for Core ***
W (199)P(00) Benchmark: *** Core 0
I (199)P(00) Benchmark: *** DAC        avg 4.334
I (199)P(00) Benchmark: *** SigmaDelta avg 0.280
I (209)P(10) Benchmark: *** Factor Dac/SigmaDelta 1500.00 %
W (209)P(00) Benchmark: *** Core 1
I (209)P(00) Benchmark: *** DAC        avg 4.313
I (209)P(00) Benchmark: *** SigmaDelta avg 0.296
I (219)P(10) Benchmark: *** Factor Dac/SigmaDelta 1400.00 %
W (219)P(00) Benchmark: ********
Interesting that in cpu 1, DAC got a little bit faster and Sigma-Delta a little slower, why will it?
Users browsing this forum: No registered users and 40 guests
