Global boolean vs EventGroup bit
0xffff
Postby 0xffff » Thu Jul 12, 2018 11:50 pm
I'm curious about the benefits of using EventGroup bits for event notification (not task synchronization) compared to a global. For example, task A can set a global boolean, which is checked by task B in a loop with task Delay:
// task A sets the marker
bool marker;
function setMarker() {
   marker = true;
// Task B checks the marker every second
while ( !marker ) {
    vTaskDelay(1000);
compared to the following pattern:
extern EventGroupHandle_t events;
   xEventGroupSetBits(events, 1);
// Task B blocks until this bit i set
xEventGroupWaitBits(events,1,pdFALSE,pdFALSE,portMAX_DELAY)
Presumably the second version will return as soon as the bit is set so there could be a lower latency to detection. Are there other benefits?
TIA
ESP_Angus
Re: Global boolean vs EventGroup bit
Postby ESP_Angus » Fri Jul 13, 2018 12:36 am
Lower latency, and also the waiting task will not run at all until the event group wakes it up - so it's not using any CPU time.
urbanze
Postby urbanze » Fri Jul 13, 2018 12:52 am
1. Block time is the best reason (I think), leaving task blocked with 0 cpu consuption (quoted above).
2. One boolean use 8bit, than, to use 24 events (1 event group), you need much more memory.
chegewara
Postby chegewara » Fri Jul 13, 2018 8:39 am
You guys are forgetting about few important things about EventGroup:
  • WaitForBits function got timeout parameter, so code can run even if "boolean" value is still false (only if you want to),
  • WaitForBits can wait for few bits to be set, with bool you have to use few global variables instead, this makes code less ram consuming
urbanze
Postby urbanze » Fri Jul 13, 2018 10:59 am
and dont forget event group special spec, ALL tasks waiting for X bit, will wake up when X bit arrive (leave blocked state to ready). Queue and Semaphr wake up only most priority task or the oldest (if tasks has same prio).
Users browsing this forum: No registered users and 184 guests
