ESP32 debugging with Segger Jlink
Karim1993
Re: ESP32 debugging with Segger Jlink
Postby Karim1993 » Thu Nov 01, 2018 8:17 am
ESP32 debugging with Segger JLink worked fine for me an Ubuntu 14.04 machine with the binaries provided. I just faced the issue with clock frequency which was later resolved.
ningappa BS
Postby ningappa BS » Fri Nov 02, 2018 4:26 am
Could you please first verify if you are able to debug from the command line, before using Eclipse? Please follow these instructions: https://docs.espressif.com/projects/esp ... index.html
you mean that "GDB debugging".
ningappa BS
Postby ningappa BS » Fri Nov 02, 2018 4:33 am
could you please share the steps you have followed because am getting errors which you can check in this conversation.
thanks
Karim1993
Postby Karim1993 » Mon Nov 05, 2018 12:11 pm
I built the openocd from source by following steps from https://docs.espressif.com/projects/esp ... linux.html
Then the command openocd -s . -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Thanks,
Karim
ningappa BS
Postby ningappa BS » Thu Nov 22, 2018 4:30 am
Thanks,
Karim
i followed the procedure which you have given in the link
Steps followed....
step 1-----> cd ~/esp
step 2-----> git clone --recursive https://github.com/espressif/openocd-esp32.git
step 3-----> sudo apt-get install make
sudo apt-get install libtool
sudo apt-get install pkg-config
sudo apt-get install autoconf
sudo apt-get install automake
sudo apt-get install texinfo
sudo apt-get install libusb-1.0
step 4-----> cd ~/esp/openocd-esp32
./bootstrap
./configure
make
step 5----->openocd -s . -f interface/jlink.cfg -f board/esp-wroom-32.cfg
this is what am getting
"Warn : Unexpected idcode after end of chain: 627 0x00000000
Error: double-check your JTAG setup (interface, speed, ...)
Warn : AUTO auto0.tap - use "jtag newtap auto0 tap -irlen 2 -expected-id 0x00000000"
Error: auto0.tap: IR capture error; saw 0x0000 not 0x0001
cpu0: Current bits set: none
cpu1: Current bits set: none"
Correct me if I am wrong and any suggestions on where I am going wrong is welcome.
let me know how to solve this.
thanks
arunbm123
Postby arunbm123 » Tue Dec 18, 2018 2:51 pm
hi Ningappa BS
Are you able to debug with Openocd and JTAG ?
-Arun
arunbm123
Postby arunbm123 » Tue Dec 18, 2018 2:53 pm
hello Ningappa
I am getting
$ bin/openocd.exe -s -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Open On-Chip Debugger 0.10.0-dev (2018-11-05-04:10)
Licensed under GNU GPL v2
For bug reports, read
embedded:startup.tcl:60: Error: Can't find board/esp-wroom-32.cfg
in procedure 'script'
at file "embedded:startup.tcl", line 60
ningappa BS
Postby ningappa BS » Tue Jan 15, 2019 7:47 am
hi,
i am using olimax debugger, it is working.
thanks,
Users browsing this forum: No registered users and 16 guests
