LoadStoreError on OTA
poengAlex
Postby poengAlex » Thu Sep 20, 2018 2:30 pm
Hi
I have some trouble with using OTA (about 1Mb bin) in a task. I use the “AWS S3 OTA Update” example in Arduino as a base and run it in a task (runs on APP core, changing priority and stacksize does not help)). Sometimes the OTA is successful sometimes it crashes at random percentage and I get this error:
Guru Meditation Error: Core  1 panic'ed (LoadStoreError). Exception was unhandled.
Core 1 register dump:
PC      : 0x400e578c  PS      : 0x00060630  A0      : 0x800e582f  A1      : 0x3ffd8f90
A2      : 0x3ffcde28  A3      : 0x3ffd8fdf  A4      : 0x00000001  A5      : 0x40000000
A6      : 0x00025078  A7      : 0x3ffd5320  A8      : 0x00000000  A9      : 0xffffffff
A10     : 0x00000000  A11     : 0x3ffdaf88  A12     : 0x00000050  A13     : 0x00000020
A14     : 0x00000000  A15     : 0x00000000  SAR     : 0x0000000a  EXCCAUSE: 0x00000003
EXCVADDR: 0x40000000  LBEG    : 0x400014fd  LEND    : 0x4000150d  LCOUNT  : 0xffffffff
Backtrace:
0x400e578c: WiFiClientRxBuffer::read(unsigned char*, unsigned int) at C:\Users\alex\AppData\Local\arduino15\packages\esp32\hardware\esp32\1.0.0\libraries\WiFi\src/WiFiClient.cpp line 507
0x400e582c: WiFiClient::read(unsigned char*, unsigned int) at C:\Users\alex\AppData\Local\arduino15\packages\esp32\hardware\esp32\1.0.0\libraries\WiFi\src/WiFiClient.cpp line 507
0x4017ab1a: WiFiClient::read() at C:\Users\alex\AppData\Local\arduino15\packages\esp32\hardware\esp32\1.0.0\libraries\WiFi\src/WiFiClient.cpp line 507
0x400ecfa1: Stream::timedRead() at C:\Users\alex\AppData\Local\arduino15\packages\esp32\hardware\esp32\1.0.0\cores\esp32/Stream.cpp line 279
0x400ecfcd: Stream::readBytes(char*, unsigned int) at C:\Users\alex\AppData\Local\arduino15\packages\esp32\hardware\esp32\1.0.0\cores\esp32/Stream.cpp line 279
0x400e2cbe: Stream::readBytes(unsigned char*, unsigned int) at C:\Users\alex\AppData\Local\arduino15\packages\esp32\hardware\esp32\1.0.0\cores\esp32/Stream.h line 103
:  (inlined by) UpdateClass::writeStream(Stream&) at C:\Users\alex\AppData\Local\arduino15\packages\esp32\hardware\esp32\1.0.0\libraries\Update\src/Updater.cpp line 319
0x400da8eb: _ota_execOTA(String, String) at C:\Users\alex\AppData\Local\Temp\VMBuilds\Proto V0.7 PCBV10\esp32_esp32\Release/Ota.cpp line 189
0x400dae3e: _ota_OtaTask(void*) at C:\Users\alex\AppData\Local\Temp\VMBuilds\Proto V0.7 PCBV10\esp32_esp32\Release/Ota.cpp line 62 (discriminator 2)
Partition table:
# Name,   Type, SubType, Offset,  Size, Flags
nvs,      data, nvs,     0x9000,  0x5000,
otadata,  data, ota,     0xe000,  0x2000,
app0,     app,  ota_0,   0x10000, 0x140000,
app1,     app,  ota_1,   0x150000,0x140000,
eeprom,   data, 0x99,    0x290000,0x1000,
spiffs,   data, spiffs,  0x291000,0x16F000,
Any suggestions on whats wrong? And what is the LoadStoreError?
Thanks!
Users browsing this forum: No registered users and 131 guests
