Problem with pullup on serial pin
Fusion
Postby Fusion » Fri Oct 26, 2018 12:43 am
Hi guys,
I have an external module connected to the ESP32 with hardwareserial as RX GPIO12, TX GPIO14.
HardwareSerial Serial2(2);
  Serial2.begin(38400, SERIAL_8N1, 12, 14);
The module datasheet states that it's UART TX pin is open drain and needs a 10K ohm pullup (in my case to 3.3V).
Problem is that when I use a physical 10K resistor, the ESP bootloops.
I have tried
pinMode(12, INPUT_PULLUP);
but there is no communication. I only get garbage in Serial Monitor when I touch the pin.
When I send something to Serial2, I can see the module's RX and TX leds blink, so something is going on, I think the ESP just isn't reveiving anything.
What could be wrong? I would rather if I didn't have to use the physical pullup resistor.
Cheers!
Fusion
Re: Problem with pullup on serial pin
Postby Fusion » Sat Oct 27, 2018 5:12 pm
12 (MTDI)
If driven High, flash voltage (VDD_SDIO) is 1.8V not default 3.3V. Has internal pull-down, so unconnected = Low = 3.3V. May prevent flashing and/or booting if 3.3V flash is used and this pin is pulled high, causing the flash to brownout. See the ESP32 datasheet for more details.
Is this what could be causing the problem? Is there a way to get rid of this function?
And why is the pin sensitive to touch even when not used as touch input and is sending garbage over serial?
Fusion
Postby Fusion » Mon Oct 29, 2018 12:04 am
@WiFive
So what is the best option in my case (ESP32 wroom)?
Is there another way to test this before burning the fuses?
WiFive
Postby WiFive » Mon Oct 29, 2018 1:23 am
Fixed 3.3V VDD_SDIO
Fusion
Postby Fusion » Thu Nov 01, 2018 6:19 am
Thank you, this worked.
Also the baud rate was 9600, even though manf. says 38400 in datasheet.
Users browsing this forum: No registered users and 133 guests
