I'm trying to use ULP for counting pulse from GPIO.
Button on the pcb board is connect to GPIO34, so I changed variable gpio_num from GPIO_NUM_0 to GPIO_NUM_34 and I wake up the ESP with using timer in five seconds periods.
I do nothing when the program is executing but I get the number of pulse in e.g. equals to 3562.
What pulses are count in this case?
ULP Pulse Counting Example
Re: ULP Pulse Counting Example
Gpio34 has no internal pull resistor so it floats and you are measuring noise
In case with GPIO_NUM_0 is the same problem.
So, what I need to do is set internal pull on the GPIO_NUM_0 pin?
OK, it is working when I use esp_sleep_enable_ulp_wakeup() function but I need to use function called esp_sleep_enable_timer_wakeup( 6000000 ). The ESP wakes up but doesn't count the pulse from the button.
Is this uses to count only total number of pulses? Not used to measure timing of each pulse ? Correct?
Regards,
Ritesh Prajapati
Ritesh Prajapati
If I would to use two GPIOs in the same time what I need two modify in the .S file?
Hi WiFive,
Would you please check my last question and provide your valuable feedback for same?
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: No registered users and 41 guests
